EDA_hg81
Advanced Member level 2
I am designing power supply for a 16bit ADC.
I used PI LC filtering to reduce power supply ripple at the switching regulator side.
My question is: should I still need to connect ferrite beads to analog power pins at the ADC side?
If I use both of them, is there any potential interference?
Do you think the ferrite bead connected with caps make another PI LC filter?
Thanks.
Thanks.
