Pi filter cut off frequency
Techman_7
Full Member level 3
Full Member level 3
The cut off frequency for pi filter ckt shown below is -
But as per simulation in LTspice (AC analysis), the above equation does not meet the simulation cut off frequency.
So, is it the correct equation applicable for pi filter.
You are showing a formula for LC resonance frequency, LC filter cut-off is most likely in this order of magnitude but not the same.
Generally, specifying a filter without source and load impedance is useless. We don't know your measurement setup and results, please show.
I agree with FvM.
So let´s say the output side is high impedance, then
* if the input side is low impedance: then f_res = 1/ (2*Pi* sqrt(L1 * C2))
* if the input side is high impedance, then f_res = 1/ (2*Pi* sqrt(L1 * Cs)) .. with Cs = 1 / ( 1/C1 + 1/C2)) = series impedance of C1 and C2
in both cases talking about cutoff frequency is not correct .. because it´s un undamped resonance.
Klaus
In case of a Buttwerworth filter with matched input and output impedance, the formula actually fits.
C = C1*C3/(C1 + C3)
Write your reply...
LaTeX Commands Quick-Menu:
