ajit_nayak87
Member level 5
Dear all,
I need some guideline to complete my project. Here is sample code where i could able to connect or any wifi network based on SSID.
1) In attached image how can i change Time to Indian Standard date & time
2)My first page should look like https://www.youtube.com/watch?v=oVTVopy0Tng as shown in video . where i could able to view parameter like this. keeping auto connect page same.
3) please suggest me in PHP how can i create my first webpage . All data is going to monitor locally.
Code HTML - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 /* Simple.ino, Example for the AutoConnect library. Copyright (c) 2018, Hieromon Ikasamo [url]https://github.com/Hieromon/AutoConnect[/url] This software is released under the MIT License. [url]https://opensource.org/licenses/MIT[/url] */ #if defined(ARDUINO_ARCH_ESP8266) #include <ESP8266WiFi.h> #include <ESP8266WebServer.h> #elif defined(ARDUINO_ARCH_ESP32) #include <WiFi.h> #include <WebServer.h> #endif #include <time.h> #include <AutoConnect.h> #if defined(ARDUINO_ARCH_ESP8266) ESP8266WebServer Server; #elif defined(ARDUINO_ARCH_ESP32) WebServer Server; #endif AutoConnect Portal(Server); AutoConnectConfig Config; // Enable autoReconnect supported on v0.9.4 #define TIMEZONE (3600 * 0530) // Tokyo #define NTPServer1 "ntp.nict.jp" // NICT japan. //#define NTPServer1 "in.pool.ntp.org" #define NTPServer2 "time1.google.com" void rootPage() { String content = "<html>" "<head>" "<meta name="viewport" content="width=device-width, initial-scale=1">" "</head>" "<body>" "<h2 align="center" style="color:blue;margin:20px;">Hello, world</h2>" "<h3 align="center" style="color:gray;margin:10px;">{{DateTime}}</h3>" "<p style="padding-top:10px;text-align:center">" AUTOCONNECT_LINK(COG_32) "</p>" "</body>" "</html>"; static const char *wd[7] = { "Sun","Mon","Tue","Wed","Thr","Fri","Sat" }; struct tm *tm; time_t t; char dateTime[26]; t = time(NULL); tm = localtime(&t); sprintf(dateTime, "%04d/%02d/%02d(%s) %02d:%02d:%02d.", tm->tm_year + 1900, tm->tm_mon + 1, tm->tm_mday, wd[tm->tm_wday], tm->tm_hour, tm->tm_min, tm->tm_sec); content.replace("{{DateTime}}", String(dateTime)); Server.send(200, "text/html", content); } void setup() { //delay(1000); Serial.begin(115200); Serial.println(); // Behavior a root path of ESP8266WebServer. Server.on("/", rootPage); // Enable saved past credential by autoReconnect option, // even once it is disconnected. Config.autoReconnect = true; Portal.config(Config); // Establish a connection with an autoReconnect option. if (Portal.begin()) { Serial.println("WiFi connected: " + WiFi.localIP().toString()); configTime(TIMEZONE, 0, NTPServer1, NTPServer2); } } void loop() { Portal.handleClient(); }
