Phase unwrapping of S2,1
RandomZed
Newbie
Hello,
I ran a simulation where I got S11 and S21 values. I'm interested in the S21 phase values but having difficulties understanding how to unwrap the S21 phase graph.
Any help on how to unwrap a phase value and what criteria do I have to meet would be appreciated.
For example, how will I unwrap the phase value at 2.45 GHz and how to also do it at 2.53 GHz
Thanks in Advance.
You cannot get absolute phase unless you sweep from a lower f where the phase is stable either 0 or 180 deg.
This plot shows d phi/ df = 1 cycle of 360 deg for a range of about 370 MHz. This is group delay = 1/delta f = 2.7 ps
This might be normal if it were a >= 12th order Gaussian or Linear Phase BPF.
Try to plot the group delay
Thanks for the reply, I tried simulating in a frequency range of 0 and 3 GHz and got the attached resutls.
I also plotted the Group Delay and attached the result as well.
Your help is appreciated
S-parameters can have a Phase between -pi and +pi radian. So This is the Definition.
LaTeX Commands Quick-Menu:
