Phase shifting without the use of DLL or PLL
anssprasad
Member level 5
Member level 5
dll phase 90
Hi
I would like to know if we can get a 90 degree phase shifted clock from the reference clock without using PLL or DLL
Thanks
Prasad.
phase shift dll
If you know the frequency of the reference clock then you can use a delay circuit with a buffer. The delay circuit can be a simple RC circuit combined with a buffer to reshape the square wave.
wouldn't this be PVT dependent ??
Can you please tell me what you meant by PVT
If you can generate double the required frequency, then a master-slave flip-flop can be used as a by 2 divider .The output of the master latch will by leading by 90 degrees the output of the slave latch .But this relies on the ability of having double the required frequency .
    anssprasad
You can generate double the frequency clock by using an XOR gate and a delay chain. Hook up the undelayed clock to one XOR input and delayed to the other, you will get a clock at twice the speed (but not 50-50 duty cycle), also the jitter of this clock will depend on the duty cycle of the original 1X clock (so it is important to make that one as close to 50-50 as possible). You can now divide the 2X clock by two and depending on your initial state and time reset to the divider is de-asserted you can get the required phase shift.
    anssprasad
