Phase Shift Keying simulation on Matlab
dammadmin
Junior Member level 2
MRU
Deat friends, im stuck with the following problem.
I need to generate a binary data stream/array e.g x=[ a0,1,a2,a3,a4,a5,a6,a7] of duration T seconds. I can do the array using rand function but still im unable to understand how to do the duration of T s.
also for me to be able to proceed to QPSK modulation i need to find the I and Q streams. For that I need to stretch the slot of each symbol in the inphase and quadrature stream t make them 2T s. then ill be able to move forward with multiplication of the symbols with cos (2 pi f t) and sin (2 pi f t )to produce QPSK..
Please help me im stuck!!!!....:cry:
Hi
Its better you try yourself to do PSK modulation.
Try yourself for QPSK.
data=[1 -1 1 1 -1 1]; % Bipolar Data
Ts=0.01; % The sampling time
T=0.5; % Period Duration
t=(0:Ts:T)';
basisFunc=cos(2*pi*t/T); % The sinusoid
modOut=basisFunc*data; % The modulated out
modOut=reshape(modOut,1,length(t)*length(data));
plot(modOut);
    dammadmin
ah.. i will give a try.. thank you.. I also look a bit everywhere.. it seems i need to set a particular frequency ( or a value for the bit duration)..
Thanks.. if im stuck i'll reply back..
Can someone please tell me how to divide a binary stream array of 100 bits to even bits array and odd bits array in MATLAB and then stretch the slot of each symbol in phase and quadrature stream making them 2T?......
Thank you very much mathuranathan for your reply....... only the following part is not working:
Si=evenBits\'*pulse;
Sq=oddBits\'*pulse;
Can you please adjust it so that it works.
Thanks again for your reply mathuranathan..........
i used it and it works well......
