ddt694
Full Member level 3
- Joined
- Dec 12, 2002
- Messages
- 170
- Helped
- 4
- Reputation
- 8
- Reaction score
- 0
- Trophy points
- 1,296
- Activity points
- 1,400
Hi, all friends
In one of my design, I received the master station' PSK waveform and the data clock had been recoveried. But the recoveried data clock do not meet the system requirement. The clock outpout from the demodulator must be very low phase noise,say, 130dBc/Hz at 100Hz.
So, I use a second phase locked loop and a low phase noise OCVCXO to retiming the received clock. But i donot know what kind of phase detector should i use.
ADF series or LMX series frequency synthesizer chips can be used for design frequency synthesizer, but these edge type detectors may be not suit for the case the reference clock is not high S/N.
Is the EXCLUSIVE-OR gate type detector more fitable? The problem is that except HC4046, there are not other high performance phase detector chips for business use.
Or, i had to use a CPLD chip to design the phase detector?
Thanks
Thanks
