Phase Locked Loop - transistor sizing forphasedetector
mytreyi
Junior Member level 3
india
Phase Locked Loop
please anybody tell me... Is it required transistor sizing when phase detector designing...iam not getting output at the PFD(iam using 0.18um cadence)...
Phase Locked Loop
Did you apply too fast input to your logic gate? Usually for D-flip flop, you need enough set-up and hold time in order to make it latch the input, I think you could check on this.
very very thanq.....
i applied delay =0ns
rise time=100ps
fall time=100ps
v1=0v
v2=1.8v
pulse width=20ns
pulse period=40ns
(W/L)n=(W/L)p=240nm/180nm
Try "sliding" the phases past each other looking for the
output to change behavior. At some phase offsets you
-should- see nothing happen. But you need to verify both
"early" and "late" operation.
    mytreyi
transistor sizing...is it effected to the output....
