Phase lock loop VS PWM
miao0810pei
Newbie level 2
Newbie level 2
Hi everyone, i need someone to help me here. I'm creating a 3 phase synchronous motor controller here. I need to understand what's the function of PWM and phase lock loop.
Thank you
PWM has its use in power supply, where PLL is a communication circuit. In PWM if your input voltage is within specified range it will give fixed output voltage; to get more idea on these find some datasheets
definition for PLL, a pll is an electronic circuit with a voltage or current driven oscillator that is constantly adjusted to match in phase (and thus lock on) the frequency of an input signal. In addition to stabilize a particular communication channel.
