bagusdj
Member level 3
hey guys. i am planning to create project using principal of phase firing angle.
my reference is this site https://www.8051projects.net/news-i188-single-phase-ac-motor-speed-controller-project-report.html. in the download page you will find the report,code,and schecmatic.
using that reference i model it into proteus: View attachment phasecontrol.rar
using the same code:
in the oscilloscope the form of wave doesn't change. what could be the cause?
when i connect the output of zcd to MCU, the probe 1 in oscilloscope read it as full dc (flat). if i dont connect it, the probe 1 read it as pulse each 10ms
#include<reg52.h>
#define bargraph P2
sbit led1 = P3^7;
sbit led2 = P3^6;
sbit s1 = P1^0;
sbit s2 = P1^1;
sbit s3 = P1^2;
sbit pulse = P0^0;
/*code unsigned char timer_l[10]={0x38,0x3c,0x69,0x81,0x99,0xb1,0xc9,0xe1,0x94,0x11};
code unsigned char timer_h[10]={0xfc,0xf6,0xf4,0xf0,0xec,0xe8,0xe4,0xe0,0xdf,0xd9};*/
code unsigned char timer_l[10]={0x38,0x3c,0x69,0x81,0x78,0xb1,0xc9,0xe1,0x94,0x11};
code unsigned char fonts[10]={0xff,0xfe,0xfc,0xf8,0xf0,0xe0,0xc0,0x80,0x00,0x00};
unsigned char speed;
bit on=0;
void delay_ms (unsigned int);
void decangle(void) //decrease delay by 1ms
if(speed>0)
speed--; // decrease delay
if(speed!=8)
bargraph=fonts[speed];
void incangle(void) // increase delay by 1 ms
if(speed<9)
speed++;
void tx (unsigned char x)
SBUF=x;
while(TI==0);
TI=0;
void int0(void) interrupt 0 // external interrupt 0 subroutine
led1=~led1; // led is on
if(on==1)
if(speed==0)
pulse=1; // oFF the triace permenately
return;
else if(speed==9)
pulse=0; // on the triace permenately
return;
else
pulse=1;
TL0 = timer_l[9-speed];
TH0 = timer_h[9-speed];
TR0 = 1;
else
pulse=1;
void timer0 (void) interrupt 1
TR0=0;
pulse=0;
void int1(void) interrupt 2 // external interrupt 1 subroutine
if(s1==0) // for first key
on=~on; // increase counter
else if(s2==0) // for second key
incangle(); // increase phase angle decrease power
else if(s3==0) // for third key
decangle(); // decrease phase angle increase power
delay_ms(300);
void uart(void)
SCON = 0x50;
TH1 = 0xF3;
TL1 = 0xF3;
TR1 = 1;
void init(void)
TMOD=0x21; // initialize timer0 as 16 bit timer , timer1 as 16 bit counter
IT0=IT1=1; // making edge trigger
bargraph=0xFF; // making all leds off
EX0=EX1=ET0=1; // enable interupts of timer0 abd external interrupt 0 & 1
EA=1;
void delay_ms (unsigned int count)
unsigned int i;
while(count) {
i = 115;
while(i>0) i--;
count--;
void send(unsigned char *str) // sending a whole string to port
while(*str)
tx(*str++);
delay_ms(2);
void main(void)
unsigned char a;
init();
uart();
while(1) // continuous loop
if(on==0)
led2=1;
else
led2=0;
if(RI==1)
a=SBUF;
RI=0;
switch(a)
case 'A':
speed=0;
send("Motor is off\r\n");
break;
case 'B':
speed=1;
send("Level 1\r\n");
break;
case 'C':
speed=2;
send("Level 2\r\n");
break;
case 'D':
speed=3;
send("Level 3\r\n");
break;
case 'E':
speed=4;
send("Level 4\r\n");
break;
case 'F':
speed=5;
send("Level 5\r\n");
break;
case 'G':
speed=6;
send("Level 6\r\n");
break;
case 'H':
speed=7;
send("Level 7\r\n");
break;
case 'I':
speed=8;
send("Level 8\r\n");
break;
case 'J':
speed=9;
send("Full \r\n");
break;
default:
on=~on;
if(on==0)
send("Power is disabled\r\n");
else
send("Power is enabled\r\n");
break;
