Let the clock frequency applied to the flip flop is 1Mhz and a high input is applied to the clock we know that the output frequency of the T-ff would be 0.5Mhz but what is the relation between the relation between clock signal applied and the o/p signal in terms of phase?
What would be the phase difference between them?
Your question is quite confusing but I think as the frequency of output is exact half of the clock when i/p is 1 so it will depend on the logic level of the clock...you didn't mention whether the FF is a rising edge or falling edge triggered one...
I think you are asking the the time between clock rising edge to output toggle. If clock rising edge occurs at t=t_0, output toggles at time t=t_0+t_delay. What is t_delay?
It really depends on the model of TFF you are using. If you are using a discrete IC, check the datasheet, if you are using an FPGA do a post-routing simulation.
