Permiability & Permitivity
avi_e-
Member level 5
Member level 5
INDIA
permiability
Hi Friends,
What are the basic theoritical definitions of Permiability(µ) & Permitivity(ε)?
How are they differed from each other literally and techincally?
Regards,
Avinash.S.
permitivity
hi avi,
permeability
1. the property of being permeable
2. the rate of flow of a fluid through a porous material
3. (geology) a measure of the ability of a rock to transmit water
4. (physics) a quantitative measure of the degree of magnetization of a material in the presence of an applied magnetic field (in terms of, for instance, Newtons per square Amperes in SI units).
Permittivity
it is a physical quantity that describes how an electric field affects and is affected by a dielectric medium, and is determined by the ability of a material to polarize in response to the field, and thereby reduce the total electric field inside the material. Thus, permittivity relates to a material's ability to transmit (or "permit") an electric field.
It is directly related to electric susceptibility. For example, in a capacitor, an increased permittivity allows the same charge to be stored with a smaller electric field (and thus a smaller voltage), leading to an increased capacitance.
    avi_e-
eletronic permitivity
Permeability (electromagnetism):
https://en.wikipedia.org/wiki/Permeability_(electromagnetism)
Permittivity:
https://en.wikipedia.org/wiki/Permittivity
difference:
permeability is the degree of magnetization of a material that responds linearly to an applied magnetic field
Permittivity is a physical quantity that describes how an electric field affects and is affected by a dielectric medium, and is determined by the ability of a material to polarize in response to the field, and thereby reduce the total electric field inside the material. Thus, permittivity relates to a material's ability to transmit (or "permit") an electric field.
So, the first one is related to the magnetic field, as another one is related to the electric field.
    avi_e-
permiability]
Oh and what you forgot to mention, sqrt(µo*εo)=c
c is speed of light
