perfect substitute for pic 16c74
harishwww
Member level 3
Member level 3
i want to know perfect substitute for 16c74 pls help me
he has not mentioned whether he want pin to pin compatiblity or he wants function wise...
that is replacement for function wise..
yes i want pin as well as function wise replacement
i think all the answer is at microchip.com..
go there and search for the datasheet and make your own comparison..
Take a look at 16c77. It's quite similar, except an extended memory,etc. Peripherals are similar.
nikhilele,
The ATMEGA8 has 28 pins and ATTINY23 has 20 pins. They are better than the 16C77 function wise but the main difference would be the pin count. The 16c74 has 40 pins.
Hope this helps.
Tahmid.
i think 16c74 is absolute in the market / no more production if you see 16F877A is much similar to 16c74
The PIC16F877A CMOS FLASH-based 8-bit microcontroller is upward compatible with the PIC16C5x, PIC12Cxxx and PIC16C7x devices. It features 200 ns instruction execution, 256 bytes of EEPROM data memory, self programming, an ICD, 2 Comparators, 8 channels of 10-bit Analog-to-Digital (A/D) converter, 2 capture/compare/PWM functions, a synchronous serial port that can be configured as either 3-wire SPI or 2-wire I2C bus, a USART, and a Parallel Slave Port.
I would suggest a move to 16F887 rather than 16F877A as it's newer and seems improved and enhanced and is compatible.
Hope this helps.
Tahmid.
As i guess you are from India, there are many vendors where you get the said device in abundant. But can you first let us all know why are you looking for a exact replacement?
i want to make led matrix display board using keyboard lcd like
  • picdis1.rar
