Looks OK to me. The regulator would stop working properly as soon as the battery started to discharge due to little overhead but the circuit should work without the regulator anyway. All it does is compare the battery voltage with the drop across the two diodes.
The stupid circuit has an accurate voltage regulator but uses diodes as its voltage reference that change their voltage when the temperature changes.
So it is a thermometer, not a pencell battery tester.
When the temperature is cold then a brand new pencell might cause the red LED to light.
When the temperature is hot then a fairly dead pencell might cause the green LED to light.
The two diodes should be a trimpot to set an accurate reference voltage that does not change when the temperature changes.
@rajaram04:
You should start learning how different electronic, active and passive, components work, not ALWAYS asking for circuit verification (the circuit that you've found on the 'net).
It is GOOD that Raj asks for verification that a lousy circuit from his country does not work because the website with this circuit TESTED it and lied about it.
This battery tester might have been tested only at one temperature. But doesn't everybody know that the forward voltage of a diode changes when the temperature changes and the voltage from a voltage regulator IC does not?
