cts_casemod
Member level 4
I need to charge a capacitor using a zenner diode. The device uses 100mA @ 320VDC and a series 100Ohm resistor results in an instantaneous maximum current of 3.5Amps. Zener is rated at 110mA max continuous current.
I know normal diodes, as used in rectifier circuits can handle this overload very well for short periods of time, but there is nothing referring that in the zener datasheet.
Any inputs here? Regards
