Meri96
Junior Member level 3
Hello everyone, although I researched, I could not understand the difference between PDM (pulse densty modulation) and PWM (pulse width modulation) in practice.
PDM: The analog modulation type in which the carrier signal pulse width changes according to the modulation signal. There is no change in the amplitude or position of the pulses. definition is made.
https://ars.els-cdn.com/content/image/3-s2.0-B0122274105001654-gr7.gif
PWM: a special case of PDM where the switching frequency is constant and all pulses corresponding to a sample are adjacent in the digital signal. definition is made.
https://circuitglobe.com/wp-content/uploads/2019/08/PWM-signal.jpg
It is described as the same in most sources, I can not see any difference in the graphics. Not used in fixed frequency in PDM? As an advantage, PDM allows ZVS / ZCS, reduces EMI, ok but how does it do it, what is the difference in implementation?
I have the stm32f103 microcontroller, can I produce PDM with this microcontroller?
