PCMCIA to RS232,Parallel port (real) port
mbyka
Full Member level 5
Full Member level 5
from istanbul in TURKEY
rs232 parallel port
Hi all
**broken link removed** SSP-100
ftp://ftp.quatech.com/manuals/ssp-100.pdf
Specifications
• PCMCIA Card Standard 2.1, Type II (5 mm) PCMCIA card
• Power Consumption: +5 VDC, 25.75 mA typical, 33.26 mA maximum
• RS-232 9-pin male serial connector
• Max. baud rate: 921.6 kbps
• 16750 UART (64 byte transmit and receive FIFO)
Selectable IRQ: 3-7, 9-12, 14 or 15
Selectable base address
• Client software driver for OS/2
• Compatible with Windows 3.x/95/98/NT/CE/2000/XP
• Compatible with most hand-held computers running under Windows CE
• FCC Class B and CE marked
ftp://ftp.quatech.com/manuals/spp100.pdf SPP-100
Specifications
• Power Consumption: +5 VDC, 20 mA (typical)
• 15 inch interconnect cable
• DB25 female connector
• Max data rate: 700 kbps
• Supports IEEE 1284 bi-directional Enhanced Parallel Port Interface (EPP)
Selectable I/O address
• Compatible with Windows 3.1/95/98/2000/NT/XP
Does anybody use these products?
is it succesfully? for more deviceand programs(Pic programmer-jdm-ICD2-Winpic-PLC-IC-Prog-Palm-Printer or another device.......)
I want to learn Your think
USB to rs232 products not successfuly.
