pcm/pcb/bms for a 4S4P
marc.collin
Newbie level 1
Newbie level 1
hi
i search a pcm/pcb/bms for a 4S4P
i will use 3100mAh battery
4S4P will do: 14.8V, 12.4Ah
Battery will be used for a light: 12V at 2A
i checked this pcm
Protection Circuit Module Specifications For 14.8V Li-ion/Li-Po Battery Pack
Model:PCM-LI14.8V10A
Over-charge protection voltage 4.350 ± 0.025V
Over-discharge protection voltage 2.40 ± 0.080V
Over-current protection 12~16A
Maximal continuous Discharging current 10A
doe the Maximal continuous Discharging will be ok?
don't know if that value must me over 12.4Ah
