Rahul Soni
Member level 1
Hello Folks,
I was looking at the PCIe CEM spec for the AUX signals (WAKE#, CLKREQ# specifically) and the DC specification says the below:
Since voltage level for these signals are mentioned as VCC3_3, i thought that we should pull these signals up to 3.3V_Main ..
But when I checked a little more in detail about Wake signal, it says that to support D3_cold scenarios, the signal should be pulled up to 3.3V_AUX, as shown below:
But when I tried to find more information about CLKREQ signal, i dont get much info.. All I get is some timing info and I see 3.3V_AUX here:
Do you know to which supply, CLKREQ signal should be pulled up to? 3.3V_Main or 3.3V_AUX?
