PCI-E
av24
Newbie
can anyone explain about where PCI-e is used and suggest any project that is involved with pci-e?
Solution
Use your favorite search engine and then utilize some time in self reading. It makes little sense for us to search out such straightforward stuff and copy paste them here.
Solution
I purchased a PCI-e wifi card (via Ebay) for my Compaq laptop computer. I had to check measurements and slot positions, and compare photographs of the 56k modem card already installed. This made me realize it was a PCI-e card. Also that it isn't the same as a PCI card.
Previously I purchased a PCI wifi card for my PowerMac. It's a larger size, with a large mounting bracket.
PCI-e is small enough to fit in a laptop.
I did not answer this Q. Well in principle a PCIe interface can be used anywhere where high volume of data needs to be moved at high speed.
