PCI card communication checking
priyaphule
Junior Member level 1
hello,
i want to develop an serial card which will be interfaced to pci bus
so.. i will get some data on the pci bus from the serial port
now how i can check whether the data reached properly at the other end of the pci bus
should i develop 2 pci cards to check the communication(which is not preferable and reliable)
mean while can i use pc to check the communication
if it is so what chenges are required at the pc end
priya
hi,
i am moorthy.now i am invoving to design PCI board.if u have full workable
PCI hardware then no problem.just download the JUNGO WINDRIVER from jungo
website.but your PCI hard ware should consist JUNGO supported devices.
bye,
here,
moorthy.T
