mahenreddy
pcb track
If trace impedance is higher than the impedance of the driver, a series termination resistor is needed at the output f the driver. How do we solve if the impedance of the driver is more than the impedance of the trace?
Besides other parameters does the material used for PCB fabrication (not the one used to draw traces) affects the trace impedance?
Is there any formula or guideline that tells when to add termination resistor?
TIA
-m
TIA
-m
