neazoi
Advanced Member level 6
Hello I have tried many times PCB tinning with liquid tin. It is in fact very convenient especially on big ground PCB traces and groundplanes, but I have some problems with it:
It does not solder very well, like pure solder tinning does.
If you leave the PCB tinned for a few weeks and then you decide to solder it, soldering is even worst as it does not solder well.
After a few weeks the "tin" gets a bit rusty, changing colour from silver to gray-silver.
This situation gets worst if you accidentally have touched the tin with your finger after tinning. It oxidizes after a few weeks.
When soldering a pad, the heat from the soldering iron oxidizes the pads near it!
If you decide to apply a cleaner, like alcohol, to clean the resin, then as you rub the PCB, some tin starts to be removed from adjacent traces and placed onto the PCB and other traces.
To overcome these problems, I do not touch the pcb with my fingers and I try not to heat it too much or clean it.
Are these "liquid tin" products really so crappy?
I do not think it is TIN that is applied on the PCB with these products. Tinning with the soldering iron and even using lead free solder makes a stable, super-easy to solder tin layer. The problem are big copped ground planes as they cannot be done with the soldering iron.
Any other ways or good chemicals to tin cheaply?
