pcb stackup thickness
mehran1367
Member level 3
Member level 3
hello
copper(mil) dielectric(mil)
top 0.7
dielectric 7
gnd 1.4
dielectric 7
signal1 0.7
dielectric 7
vcc1 1.4
dielectric 10
gnd 1.4
dielectric 7
signal2 0.7
dielectric 7
vcc2 1.4
dielectric 7
bot 0.7
is it possible to build this stackup according the presented thickness of different layers?
tanx
You didn't mention what material you are using, but assuming that the substrate and prepreg are available in your desired dielectric and copper cladding thickness, the above stackup seems completely feasible. As mentioned by barry, you should inquire with your PCB manufacturer to see if they have the material and ability to process your desired stackup. If it's generic FR4, then you can get that in almost any combination of dielectric thickness and copper cladding.
yes, I see no problem at all.
