PCB solderable Banana Plug Terminal (female)
sapphire_2010
Member level 5
Member level 5
I was looking for a PCB solderable female banana plug/ terminal (one straight and one right angled). 4mm should be ok.
But I am given current requirement to be 100Amp which is a DC pulsating current (where voltage=1500V). The duration of this instantaneous pulse current is only 50 micro second.
I have two questions here:
1- how do I choose a banana plug based on pulsating current? Any recommendation on banana jack part number?
2- is there any formula to convert pulsating DC value to steady value, since connector datasheet has values given for steady current and voltage values.
Never heard of a connector specification called "steady state current".
Connector currents are RMS currents.
--> calculate the RMS value of your pulsed current
Formulas are given in the forum many times and even more in the internet. A simple search for "pulsed current to RMS current" gives a lot of useful hits.
Klaus
Your missing specs are the impedance of the 1.5 kV and 100 A, and the voltage drop on the connector during 100 A and the risetime expected.
Is there a repetition rate of the 50 us pulse ?
In other words, what is the load power vs desired loss in the connector is not defined. Is the load a flyback L or a C discharge or just R with minimal ESL?
LaTeX Commands Quick-Menu:
