dunn
Full Member level 3
thermal relief pcb
PCB routing question
A power supply (PCB type) requires to be routed (approximately 30V DC 5A output).
As the current is high I guess I should use Thick Track (to the output).
If I a thick track (a large amount of copper) I will require "Thermal Relief" on the pad to the power supply.
If I use thermal Relief the copper around the PCB is reduced so the current carrying capability is now low.
So do I use Thermal Relief or not?
Thanks for all the help given (and even if none is given thanks for taking the time to read this post).
