hi,
well i just had a green pcb protective coating, but when i tried to apply it i had a problem that its a thick coating .
i can't get a thin layer over the board so it goes darker.
i need to get a thin soft layer of it.
any ideas?
hint: i'm not talking about solder mask:!:
TeE ThE EdE
A lot of guard-type products are alcohol-based so it is quite possible that you can use isopropyl alcohol or methylated spirit as a tinner ..
coool ,
so, do u've any good way to apply it to the board with a good finish look.
is this protective mask must be treated like this coz i bought it in a small expensive very thick quantity.
thx anyway
TeE ThE EdE
