When I used EAGLE CAD software for laying out most of my PCBs, I recall that Beta Layout (PCB-POOL) provided a Design Rule Check (DRC) file that could be easily loaded into the board file.
Is there a similar way of setting up the design rule check in Altium Designer? Can the design rules be exported from one PCB file and imported into another PCB file? (I need to produce several PCBs using the PCB-POOL service; these PCBs have two, four, and six layers.)
I am interested in which design rules need to be set up in Altium Designer to successfully produce PCBs with PCB-POOL. There are quite a few design rules listed, and I am not certain if all of them are equally important.
Has anyone used Altium Designer to successfully produce PCBs that could be manufactured by PCB-POOL? Which rules did you have to set up, and what are the min/max constraints? Are there any gotchas that I need to be aware of before submitting my design?
