PCB board Design
I recently purchased an SD / MMC card socket. But I can't seem find a PCB layouut software that has them. It's areally odd shaped MMC socket in that the pins are UNEQUALLY spaced, and lie beneath where you insert the MMC card. I was wondering is it possible to use standard PCB software to draw the board and the later fill it up manually (by pencil) on the print out. If it isn't possible anyone know any PCB software which has this components in the library.
I tried Eagle with the yamaichi, but it only has the Sd/MMC socket with the pins at the front and not beneath the card.
Thankx.
