cupoftea
Advanced Member level 6
Supposing in your PCB and gerbers, your board edge line is 0.254mm wide (thick). Will the PCB manufacturer take it that the actual “edge” is in the middle of the line?
That's the usual interpretation of contur lines. If you are unsure, why don't you reduce the aperture?Will the PCB manufacturer take it that the actual “edge” is in the middle of the line?
