michcfr
Hello,
To fasten a PCB inside an enclosure, the traditional way is to drill a hole at each corner of the PCB and then use a screw or standoff to fix it on the enclosure.
As alternative I am wondering if we can use magnets: tiny neodymium magnets are soldered at each corner of the PCB like a SMD component. The PCB is then placed on a metallic part/plate on the enclosure.
Is it feasible? I did not find any SMD solderable magnet or examples on the market/web.
If yes, what are the advantages and drawbacks of this solution?
Regards,
Michel
Regards,
Michel
