pcb DRY DILM problem
Full Member level 4
Full Member level 4
egypt
pcb DRY fILM problem
i buy from china negative dry film.
i use soduim carbonate to developing dry film . after developing i see the copper
when i put pcb in ferric chloride to etching it. the pcb is not etching because there are an Transparent layer of dry dry film " i use a correct layer of dry film i know there is 3layer sandwitch". i try all thing and no solve
are the problem in developer ?
Re: pcb DRY fILM problem
Did you do samples by yourself ?
this photo the pcb in the ferric chloride and the pcb copper not etching and copper still shiny
are there problem in dry film ?
from the image it shown that you are etching the pads ? and how do you find the "transparent layers"
ii have big problem with dry film
i use soduim carbonate to developing dry film . after developing i see the copper good
when i put pcb in ferric chloride to etching it. the some pcb area is not etching because there are an Transparent layer protect copper from etching " i use a correct layer of dry film i know there is 3layer sandwitch". i try all thing and no solve
here is another picture
