T
treez
Hello,
We have 42 PCBs each comprising a DCDC module which delivers 6.6A of current (48Vout) . All these PCBs must deliver their output current into a busbar. The busbar piece that connects to each PCB is some 5mm square cross section and made of copper.
All the PCB Bus bar mounts that we see look in danger of breaking off the PCB…eg the following…
https://i.stack.imgur.com/8GQbr.jpg
We could drill a hole in the bus bar and then have a double ended ring terminal’d wire piece to jump from the bus bar to the PCB. However, we wondered if there are some bus bar mounts which screw into the PCB, and also solder to it? (we need the screw connection aswell so it doesn’t rip off the PCB).
So you know of any “screw and solder” bus bar mounts for PCBs?
