pasau
Newbie level 5
Hi, i am working on a design with this chip: https://www.digikey.com/product-detail/en/csr-plc/CSR8675C-IBBH-R/CSR8675C-IBBH-RDKR-ND/5423495
It is 0.5mm pitch, ball diameter of 0.3mm, and my landing pads are 0.25mm. After much research i came across 3 options to do the fanout on my PCB, and i would like to minimize the cost. The options are:
1- dog-bone
2- via-in-pad
3- traces between pads
i know each of them have there advantages and all, but i would like to get a rule-of-thumb approximative comparison of pricing depending what technology i require, and possibly other advantages.
1- needs small micro-vias technology (~0.075mm laser drill) + 0.075 to 0.1 track width and clearance for the annular ring. I cannot fit more than 10 mils for total via size in dog-bone way.
2- need mfg that support via-in-pad, but drill size can be much bigger than option 1. i can use 6mils drill, so probably cheaper
3- need 3/3 mils track width/clearance to pass between pads.
In all 3 options i will most likely use blind and buried vias.
Option 1 seems to be the most interesting option, but not all mfgs support laser drill, and i don't want to go for an option that is 10x more expensive than the others, so i need to get an idea of prices in general.
thanks in advance!
1- dog-bone
2- via-in-pad
thanks in advance!
