PCB antenna at 868MHz
Humungus
Full Member level 6
Full Member level 6
pcb antenna nec
Is there any tool for the design of a PCB antenna at 868MHz?
868 mhz pcb antenna layout
There are many tools. You can browse the RF forum, or simply run search for the words 'antenna' and 'design'.
nec
used nec... if wire antenna is needed.
You could try using EMpicasso Antenna design sofware.
Phil 8)
