Apr 4, 2012 #1 K keen Full Member level 2 Joined Jul 18, 2001 Messages 123 Helped 2 Reputation 4 Reaction score 2 Trophy points 1,298 Activity points 881 Hello Friends, Can somebody explian how to import PCAD2004 files: Lib, Sch, Pcb, in to the ALTIUM 10 ? ... PCAD2004_lib,* => ALTIUM, seems Import Wizard not works, empty .... ... File, Import Wizard, Next, Select Type: Window is empty, nothing for select no progress, nothing happend, .. I am new, learning Altium, wanna escape from PCAD .. regards K.
Apr 5, 2012 #2 loosemoose Full Member level 5 Joined Dec 9, 2008 Messages 319 Helped 128 Reputation 258 Reaction score 115 Trophy points 1,323 Location Vancouver, BC Activity points 2,662 you need to click the add bottom on the bottom left.
Apr 13, 2012 #3 K keen Full Member level 2 Joined Jul 18, 2001 Messages 123 Helped 2 Reputation 4 Reaction score 2 Trophy points 1,298 Activity points 881 Moose, I click: File -> Import Wizard, but I do not get such picture as you sent ?? In: File -> Import the choice dialog is empty !? what I am doing wrong ?
Apr 13, 2012 #4 loosemoose Full Member level 5 Joined Dec 9, 2008 Messages 319 Helped 128 Reputation 258 Reaction score 115 Trophy points 1,323 Location Vancouver, BC Activity points 2,662 You may need to download all the importer and exporter plug-ins for Altium
May 26, 2013 #5 S skman Newbie level 1 Joined May 26, 2013 Messages 1 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,284 Hi, I'm having the same problem. But, when I went to DXP Plugins&Updates, this is what I find What did I do wrong during the installation? Regards
May 27, 2013 #6 A anilrock87 Full Member level 3 Joined Mar 7, 2012 Messages 187 Helped 90 Reputation 180 Reaction score 88 Trophy points 1,328 Location bangalore Activity points 2,146 Hi, This seems your repository location is not set to valid path,Go to DXP/preferences/General(Installation Manager) here you set remote repository path to https://installation.altium.com. Then try to install importer/exporter plugin.
