SphinX
Advanced Member level 3
p-cad footprints
I made the batronix programmer for AT89C20\4051 microcontroller.
I build the double side pcb i found at this site.
But when i tried to build their AT89C51\52\55 programmer, I found that the pcb is complex {there many Ics pins connected as via }
So i decided to build my pcb.
I used PCAD 2002 to build my schematic.
I choosed all footprints manualy.
Then i genereted the netlist.
But when i load this netlist in PCB,it gives a error
Error: Net NET00000: Pin 1 of D2-1 not found.
Either pin does not exist or TYPE and PATTERN are ambiguous.
Error: Net NET00000: Pin 1 of T2-1 not found.
Error: Net NET00002: Pin 2 of D2-2 not found.
Error: Net NET00003: Pin 2 of T1-2 not found.
Error: Net NET00004: Pin 2 of D1-2 not found.
Error: Net NET00004: Pin 1 of T1-1 not found.
Error: Net NET00004: Pin 2 of T2-2 not found.
Error: Net GND: Pin 1 of D1-1 not found.
Error: Net GND: Pin 3 of T1-3 not found.
Error: Net NET00048: Pin 3 of T2-3 not found.
What i understand it. the footprint of D1, D2, T1 and T2 is not match
D1 is LED, I enter the footprint LED100
D2 is Zener, I enter the footprint DO-35
T1 and T2 are BC548 transistors, i enter the footprint TO-92
What is the problem ? please ?
Thanks
Thanks
