PC won boot after inserting ISA interface card
salv
Newbie level 2
Newbie level 2
ISA Problem!!!
Hi!
I would just like to ask if anyone can help me??...
the problem is about the ISA interface
card that we made..when we tried it on the slot
the pc won't boot..what do you think is the problem...:cry:
Re: ISA Problem!!!
Do you check for address or interrupt overlap? You can't just plug in the card and expect that it will work out of the box without properly setting it. Check jumpers/dip switches to verify that you card doesn't use any of the interrupts or address already used on your system.
Re: ISA Problem!!!
thanks!! we just made our isa card work..we've found out that some pins were shorted!!thanks a lot!!
