chandlerbing65nm
Member level 5
Hi folks,
I have this ADM3202 in my board which is to be used to communicate serially from PC to MCU and vice versa. It's main functions are to send commands from PC-MCU and receive sensor data (fprintf) from MCU-PC only.
I wonder what external connector should I use to connect it to my PC.
1. DB9 RS-232 Serial to Terminal adapter Connector Breakout Board
2. FTDI Serial TTL-232 USB Cable
I don't have the actual hardware yet and the board, so there is no way I can test it practically.
If someone can help, thank you very much!
Regards,
Chandler
Regards,
Chandler
