PC Smps in Standalone Mode.
rauol
Full Member level 6
Full Member level 6
India
pc smps pinout
I want to use a PC smps to power a 12 volt 60 watt DC motor.
i want the pinout of the ATX connectror and the details of starting it
smps standalone power generation
You can find ATX Power Supply Pinouts at this url : https://pinouts.ru/data/atxpower_pinout.shtml
Note that for using the supply you must connect pin14(/PS_ON -Green Wire) to pin13(GND -Black wire).
    rauol
stand alone smps
You might have a problem starting the motor. Starting current can be greater than SMPS specifications and protection can switch it off .
    rauol
