technoqwerty123
Junior Member level 1
Hello,
I have designed a 250W boost active PFC with an output voltage of 400V. Is it safe to drive a standard 250W PC SMPS as a test load? Are the SMPS switches rated for this regulated Vin of 400V? The SMPS spec states an ac input of 120/230 Vac which transforms to a max 325V dc after rectification. Usually the design should acconut for a 20% safety margin while rating components. So it seems that the SMPS can safely sustain around 390V at its input. Any ideas?
Regards
Regards
