pc interface microcontroller using vb
daksh
Newbie level 3
Newbie level 3
pc interface with vbasic
hi,
pls can u help with interface of PC with µP
i need for my be project
i am using VISUAL BASIC6.0 and microcontoller89C51
interfacing microcontroller with vb
Make a project in VB with MSComm control, set baud rate, parity and handshaking matching your microcontroller. To send data, write to port buffer i.e. MSComm1.Output = "Hello World". In your mcu read the data (either polling or interrupt driven) from UART register.
smainj and mcu french
watch this
**broken link removed** :D
mscomm control the micro controller
thank u for the procedure but pls let me know
how to look out for the steps to interface to interface pc microcontoller using vb
there block diagrams hardware specifications and voltage level
do i require MAX 232 forthe project
microcontroller in vb
Private Sub Form_Load()
MSComm1.CommPort = 1
MSComm1.Settings = "9600,N,8,1"
MSComm1.InputLen = 1
MSComm1.PortOpen = True
End Sub
Private Sub Command1_Click()
MSComm1.Output = Text2.Text
End Sub
Private Sub MSComm1_OnComm()
If (MSComm1.CommEvent = comEvReceive) Then
Text1.Text = Text1.Text + (MSComm1.Input)
End If
End Sub
Private Sub Form_Unload(Cancel As Integer)
If MSComm1.PortOpen = True Then
MSComm1.PortOpen = False
End If
End Sub
    daksh
pc interface vb6
how to get mscom icon in the visual basic enviroment
how to interface pc to microcontroller using vb
There is a good explaination of project for pc interface microcontroller using vb.
Thank You....
vmax
