PC BIOS chip data structure
xuyinghui
Junior Member level 1
pc data structure
I want to know the structure of the content of PC BIOS chip, i.e. the locations and structures of instructions area、data area and else .
How can I find these information?
the rawest form of this data would be the source code
I might be able to provide more information from my Phoenix Technical Reference Manual, which is woefully ancient
Award source code is so complex for me
I'm puzzled about what to start to study.Is there a brief PC bios content discription?
Can you send me a copy of your phenix manual?
my email: xyh@c166.org
I suppose that there is no strict data structure and layout connected to BIOS based code .
If I am not worng BIOS has defined by its standard which clarify interface to BIOS and it is functions . Each BIOS should be specific to the motherboard it is placed on .
General standard for BIOS or at least link could be found from PC guide line .
PC Guide line is couple of standards ruling PC internal architecture . Go to the Microsoft site and begin search . But information is spread over different manufactures (Intel , IBM ...).
Follow links from
documents
Finally take it at
What I meant is simply to assert my instructions into BIOS chip. So I should know where is the instruction area in BIOS chip. Should I refer to x86 CPU user manual?
there are a number of fixed location data structures in a pc bios chip. the bios id string, the hard drive descriptor table, the compatibilty segment and, i would guess, the plug and play descriptors.
this pdf talks about some of these fields:
https://www.amd.com/epd/desiging/evalboards/14.elansc400/bios/syssoft/manual/ssman.pdf
the compatibilty segment contains jumps to various bios routines and data structures
I don't believe the book i have is worth scanning, it is 12 years old and makes no mention (for instance) of plug and play.
That is a wonderful technical reference for me.
Thanks a lot!
