pisoiu
Advanced Member level 3
Many commercially available PC based DSOs sample signals up to few hundreds MSPS in real time mode and up to few GSPS in repetitive mode. For real time mode, it should be no problem to aquire data if the banwidth of the analog section is at least up to Nyquist rate. But in repetitive mode, the analog section should respect the same criteria in order to be able to accurately represent a signal. For a few hundred $ scope is not a problem to have a 100MHz bandwidth if the real time sampling rate is 200MSPS, but if the sample rate in repetitive mode is 10GSPS, then a higher bandwidth is required, up to 5GHz to respect the Nyquist criteria, and this seem pretty hard to do at this price. Then what is the purpose of such high rate in repetitive mode? Just commercial bravada? Or just to see the same waveform with the same maximum frequency components acquired with more samples? No matter how high the sample rate is and what tricks are used in order to raise it, the maximum frequency will be bound to the bandwidth of the analog section.
/pisoiu
/pisoiu
