pbp2.42 & reading ds1820 6 writing data to 24cxx
klemm
Member level 1
Member level 1
ds1820.bas
I'm looking for a pbp code for reading data from a ds1820 and storing this data to a 24cxx. At the end I would like to send the eeprom data to the serial port and to a lcd. I have tried something but writing and reading from the eeprom won't work correctly.
Thanks
Klemm
ds1820 pbp code
Thanks
Klemm
Hi!
I have used som code done by Randy Rasa, works fine for me.
h**p://ee.cleversoul.com/xicor25_source.html
Maby it could give you some ideas.
Regards
ds1820 serial port read
It looks to me that you need whole project. Ok, let's go step by step.
- ds1820.bas - read temperature from ds1820 and show on LCD
- eeprom.bas - take data from portB and write to I2C EEprom and read it back
- rs232.bas - send data (2400 baud) to PC and receive back from PC
If you need shematic diagrams for above sources, just ask.
I hope you will find your way. I could write the whole program, but there will be no fun for you.
regards
meax98
Hi, everybody
I'm newbie in the PIC project's, and I try build a temperature logger with PIC16F84A, DS18S20 sensor and 24LC256 eeprom.
I find in net, a project in hxxp://www.nomad.ee/PIC/picprog.html, but not work.
So, I read that post and it's that I want.
Dear @meax98
It's possible post the shematic diagrams for above sources?
Thank you.
Best regards,
jEdS
