I tried another exams. 18f4550, cdc, mouse, jademo .. with 20Mhz xtal. but Full speed mode works only with usb2.0 hardware.
If you want to use with usb 1.1 compatible hw. pic should works at 24Mhz (20Mhz xtall), and fuses must set correctly as mentioned *.txt which in usb18 folder (pbp2.46).
