Pausing the LCD screen
natasie
Member level 2
Member level 2
hey guys
please i want to know how to pause the LCD screen. In the LCD command register, there is nothing stated about pausing the screen. is there anyway that
when p1.1 is high
my LCD will display "HALLOWETH BE THY NAME"
and be paused on the screen i.e. it wont write it again and again and again.
and when p1.1 is low, it will clear.
please help me with the simple code. thanks
I think you need to put a Dummy loop after writing to the LCD.
Dummy loop is a loop which does nothing but consume some amount of time; so a user have enough time to recognize the message on screen.
Use two or more nested loops to consume at least 1-2 seconds between consecutive LCD messages.
so there is no command then? i thought so too. thankyou
The LCD shows the same data until you send a new command, what you refer to seems to be more about the code flow than the LCD itself.
You can use a flag, for example value_shown, set it to 0 when the data has changed and the display needs to be updated and then set it to 1 so that the display is not updated until new data are available.
Code C - [expand]
8
9
10
11
12
while(1) {
  if (!value_shown) {
    // use the LCD routine here
    value_shown=1;
  // when the data changes in another part of the code then set
  value_shown=0;
Alex
