path thru terminal / spectre -W
imankian
Newbie
Newbie level 1
Hello,
I am using Cadence and I wanna inspect the version of spectre which is currently being used by Cadence.
Does anybody know which path thru terminal and I should type "spctre -W" to see the version of Spectre.
Try typing "spectre -W"
Another way to get at the info is by the 'which' command. But, if neither of those work, then I recommend asking whoever was supposed to install spectre in the first place.
If you are really desperate, you can try: find /. -name "spectre" -print
