T3STY
Full Member level 4
This is a project of a friend of mine, and he's having some troubles making a crossover filter for his 20W loudspeakers (8Ohm). The crossover is made using RC filters and the loudspeakers have a medium-low speaker with a range of frequencies from 20Hz up to 3kHz, and a medium-high speaker with a range of frequencies from 3kHz up to 16kHz.
Now, theory says that a LPF and a HPF made as a RC circuit should work, but when actually connecting the crossover to the speakers no sound can be heard. I suppose, RC is not the way to build crossovers, moreover, I've always seen LC filters used for passive crossover, not RC. Can you confirm this is the issue?
