passing value from javascript to c
ALMIGHTY TECH
Member level 3
Member level 3
hello all friends..
i want to pass the value from javascript to c.
printf("<script type=\"text/javascript\">\n");
printf("function displayResult(n)\n");
printf("if (document.getElementById(n).value ==\"ON\")\n");
printf("{document.getElementById(n).value =\"OFF\";}\n");
printf("else {document.getElementById(n).value =\"ON\";}\n}");
printf("</script>\n");
i have used javascript in c. as you can see above..
now i want to pass the value from javascritp to c..
there is 'if' condition in javascript,
i want to assign value to c variable, if ('if' of javascript) condition become true ..
kidnly reply..
The javascript will execute on the machine that is running the web browser, whereas I think any C code that you write you will wish to run on the web server,
right? If so, then your problem can be broken down to a need to transfer the result of the javascript execution to the server, via the network connection.
The conventional way to do this is to use (say) PHP running on the web server, and therefore PHP could execute a C program (and pass a parameter to your
C program), or alternatively use PHP to write to a file, which your C program can parse.
